I have a stock 1970 Bronco U14 half cab. I plan on replacing the following items:
· Disc brake conversion
· 2.5 suspension lift with Bilstein shocks (will probably remove smallest leaf)
· Body mounts
· All tie rods
· Column shift linkage items
· Rear axle seal (appears to be leaking)
For those that have done the same or similar work can you share the best order of replacement for the item list above and any lessons learned along the way. Any advice or tips is greatly appreciated.
Thanks!!
Jeff
· Body mounts
· All tie rods
Thanks!!
Jeff
