Ark Bigfoot
- Jan 22, 2020
- 114
I have a 1972 Bronco and was having difficulty putting it into 4 wheel drive. I removed the transfer shift cover and saw there was excess "play". I tightened up the transfer case nut but it did not take the "slop" out. I found out it was a bolt going all the way through and I was turning the entire bolt 1/16 turn at a time. lol The nut seems to have bottomed out. The up and down movement is tight only the side movement is loose. It will shift but is very difficult. Once it moves with a hard force. it gets easier for a while. LIke going into Lo 4WL is hard but back to N is easy but other gears take more force.. The transfer shift handle button works as it should and moves the lever up and down into the groves in Lo 4WD and Hi4W . How do I take the "slop" out and is there something else which needs replaced to make it shitf easier?https://www.flickr.com/photos/77159845@N07/50841849248/in/dateposted-public/
