Kniteopp
Hi Guys,
So awhile back I had mentioned had bought a Bronco finally but had never posted pics of it here. So here are some pics.
It's a '72 with a 302, 3 on the floor, twin stick. 2.5 susp lift, 33's, dual shocks
Has the dana 44 front and 9 rear geared 3.50. Disc brake conversion is already in it. All new bushings. Clutch is new but they didn't resurface the flywheel for some reason.
Since I got it I have cut out all the rusted areas..wasn't bad really. Por 15'd the bed except for passenger side, will finish that next week. Dropped the aux tank, it was shot. Sanded down this last weekend so it's nearly ready for primer.
Rust spots that were bad were floor pan, passenger rear door post. Pretty much it. Everything else was minor.
Tuned the engine in so it runs smooth as butter. Need to resurface flywheel one of these days, has some chatter. Mechanical is sound.
Wheel wells are cut out, going to work with a guy down in portland and fab a custom setup.
In any case next several posts will be pictures. I have a really, really bad head cold right now
