sean lalley
Very Clean 1973 Ford Bronco complete frame off rebuild.
some new parts include Floor pans, Wire harness, Wheels and tires, Gauge set, Sound bar, Headlights, Ididit Steering Column, Windshield, Back Glass (both glued in), Hood, Flares, Headers, complete exhaust system, Tailgate, Aluminum 4 Core radiator, Starter, Alternator, A/c compressor, air intake, battery, Front disc brake conversion, Bronco life front and rear bumper, 1 inch body lift, 3 1/2 inch bronco hut susp lift with all new bushings, all fluids replaced with royal purple replacement
Some rebuilt parts Motor, transmission, transfer case, front and rear axle, front seat are bucket with flip up console in middle to allow 3 people to ride
Bronco went frame off and was blasted and painted with chassis saver then with urikem single stage paint on frame motor was taken from 2000 ford explorer broken completely down and worked over at machine shop then rebuilt from top to bottom with only the best parts. Motor is 302 gt40p has around 300 HP at crank, Transmission is 4r70w completely broken down and rebuilt with red line parts and advanced adapter to adapt to the rebuild Dana 20 transfer case. Bottom of bronco body was sprayed with professional grade under coating before placed on frame, inside of the bronco and under hood was sprayed with liner extreme along with underside of top, exterior had minor body work completed and marker lights removed before painted with urikem base coat clear coat. top color is royal blue and bottom in charcoal grey Has nice set of 35 12.50 18 federal wrapped around 18x10 fuel wheels. bronco runs and drives great a/c will freeze you out and heater will burn you up gets almost 14 mpg and will easily do 80 on the highway with no issues, I just completed a weeks worth of cruising the coast and had no issues sitting in traffic for hours with a/c on and temp never got over 195, has vintage air sure fit a/c kit in it, has bronco hut front power disc brake conversion, Headlights have led halos and are hooked up as daytime running lights
only issue with bronco that I know of Front drive shaft not installed because it has to be lengthened due to transmission conversion, steering gear box has small leak on it
I am sure that I have forgot plenty so feel free to ask any questions that you may have
located in Biloxi ms but will assist with shipping in the us (will not ship until payment has cleared for 14 days)
questions email, text, or call 228-860-2629
