one last try for $15,000
Just got the bronco out of the shop. Hesitation issues taken care of. Turns out there was a gasket under carb ? that was completely burn up and the coil was wired backwards. Easy fix. While in the shop I had both driveshafts replaced, alignment done, Brake booster added. Several other small details done also cant remember at the moment. Anyway, I have driven it several times this week to work and it drives/stops great. Had it up to 65mph with 3 fingers on the wheel, no problem. Stops on a dime with the new booster.
On the bad side-
I took the hard top off to take some pics and it pretty much fell apart. It was so rusted around the drip rail that is just split along the entire length. For this reason (no top) I think $ 15,000 is a fair price and I am pretty firm on that if anyone is seriously interested. Minus the top this bronco has had the bugs worked out. Oh, almost forgot I also have the set of stainless steel lift off hinges from Tom's that will go with it. Have not installed them yet.
