1975 Bronco Owners Please Help!!!
thesnake
I was wondering what color of grommet you have on your ignition modules. I have one that has a black grommet and have ignition problems and I was wondering if you guys could help me out. It's stock 75 ignition and wiring.
Thanks guys!!!
John
RKM
Huntingtown, MD
This is my 75 all origonal wiring. Is this the module you are refering to
76 explorer
oklahoma city
in my old 75 it had a green grommet on it but after replacing it it would crank and then keep cranking after i let of the key until i unhooked the battery. i took the modulator back and got one for a different vehicle that had a green grommet and it worked like a champ. (at least i believe it was green)
airman
Its really disgusting how clean it is under your hood! (I mean nice Bronco and good work.)
Mine is green too.
Jeff in AZ
RKM
Huntingtown, MD
Thanks ;D . I almost was stuck between 3 colors at the time Your color green, 99 mustang cobra green, bright silver, and my 93 mustang cobra vibrent red. I always wanted the cobra. So that is why I ended up with the red. Your rig looks great also.
U
Unregistered
Guest
Hmmm....Your plug ain't green no more.
My '75 is green. I've gone through a couple modules on it.
Ed
RKM
Huntingtown, MD
Yea, I don't know if it is a 75 harness or not. The PO had this rig stripped to a bare shell on a frame when I bought it. He was an electrical engineer. He went through the hole entire electrical system. He laid it all out on the floor and tested and repared any bad spots. Luckly all the wires were still good. He said. He just went through the spedo cluster and had to redo some stuff. I guess he could have bought a harness off another rig. He said it was the origonal. But who realy knows.
thesnake
thesnake
I looked up a replacement on napaonline.com and there's has a grey grommet. I'll have to go a pick one up at a salvage yard to see if I can find a green grommet one.
John
Paperboy
My 75 parts truck was running a NAPA Echlin TP 36.. It ran fine until most of the body fell off. It has been sitting a while. :)
The pictures of the module are attached.
