1975 Build Thread
Cole Weyand
Cole Weyand
Cole’s Classic Trucks
Stanfield
Working on the tub lately, Front door post all finished up and sealed up. Moved to the passenger side rocker and found someone handy work. About a one inch of bondo on the side. So next on the list new rockers on each side. But for now some painter tape to cover the massive hole in the rocker.
Cole Weyand
Cole Weyand
Stanfield
More work done on this tub, wheel tubs and front half is painted. Fixed the passenger side core support mount. Then finishing painting the front.
Cole Weyand
Cole Weyand
Stanfield
New dash and placed a 35 to see how this bronco will look. After some more painting it will be ready to be placed on the frame.
Cole Weyand
Cole Weyand
Stanfield
It almost time to finish the frame. Brake lines and fuel line are installed. Making sure everything looks some what factor. Hopefully in a couple of weeks the tub will be installed. Also removed the passenger head for the like 5th time to make clearance.
Speedrdr
Legend in my own mind
Paris, MS
35 looks pretty good on the rear…but will it clear everything on the front? Not sure if you’ve checked it on the front yet.
Anyhow, it’s looking good, Cole.
Randy
Cole Weyand
Cole Weyand
Stanfield
Randy
Definitely will in the end, it will be a 4.5 lift. Should be able to run a 36 or 37 comfortably.
Cole Weyand
Cole Weyand
Stanfield
No lift, no problem. Primer tub is final mounted.
Cole Weyand
Cole Weyand
Stanfield
More work on the tub. Driver floor pan fixed and rear floor section fixed.
Cole Weyand
Cole Weyand
Stanfield
Passenger floor is all finished. Some one used bondo to mount the floor.
Cole Weyand
Cole Weyand
Stanfield
Both rockers are finished, all random holes are filled. rear quarter fixed. Also got a roll cage for it.
Cole Weyand
Cole Weyand
Stanfield
Tub Is almost finished, almost time for body work.
Cole Weyand
Cole Weyand
Stanfield
Installed a new rear axle with 4.11 and a Detroit locker. Also a 23 gallon tank
