• Be EXTREMELY cautious if someone offers to buy your Bronco for more than your asking price and sight unseen. ESPECIALLY if the buyer is overseas. It's probably a scam.
    Discuss it more here:
    http://classicbroncos.com/forums/showthread.php?p=514932
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on. - Thanks!
GA 1976 half cab
Status
Not open for further replies.
01JLH
Guys, I have decided to sell my 76 half cab. Fiberglass half cab with oem bulkhead. It is a pretty solid truck. The floor pans have been replaced in the foot well. Done by previous owner with flat metal. I would have used factory style but it is solid with old metal removed. I bought this truck as a uncut, stock lift truck with the original muffler still in place and built it into what you see. It has 3.5 inches of suspension lift and 2 inches of body lift. All springs, no blocks. 8 shocks with 2 in the rear being air lifts for trailer pulling or any added weight to rear. 4.56 gears Detroit in rear and new trac lock in front. WH extreme drive shafts. NV 4500 trans. 5.0 roller motor with custom ground Comp cams roller cam for this application. Motor was balanced and had full professional rebuild when installed. 600 holley carb with electric choke and has performed flawlessly. Flow cooler water pump. Every seal, bearing and gears are new (when truck was built) from bumper to bumper. Y steering was converted to T style using WH complete kit. Warn hubs on front. WH twin sticks on D20. Tires (5)are 315-75-16 Maxis buckshot mudders 75% tread. Have always been rotated regularly moving the spare in to extend life of tires. 9000lb warn winch, CB, 2 spare gas cans on rear bumper. Roll bars inside cab and in bed from complete off road. I have driven this truck to Northwest florida at least 3 or 4 times and to the mountains (gatlinburg) at least 4 times. I virtually drive this truck every day. I would trust it to go coast to coast. PM with any questions. Thanks,JLH
pierr
Gordon,GA
It stormed pretty good in GA today;). I'm sure he'll give us more pic's when the sun returns! pierr
DWALKER
Man Joey I sure wish I could swing it. This is a very nice Bronco.
01JLH
Doug, wish you could as well. I would like for it to go to someone who could appreciate the work that went into it. As you know it has the wish list of upgrades for a totally functional and capable bronco. The only thing two things that I will eventually upgrade if I keep it is the paint and it still has 28 spline axles in the rear. I personally have never broken an axle of any kind because I just don't abuse my gear so I have not seen it a priority to go bigger on those. The paint could be better but for what I use it for it is fine as is.
01JLH
More pictures
Here you go.
01JLH
a couple more
Here you go.
JedDaniel
Jasper Alabama
do you take credit cards
This is a nice bronco ,I know you put alot of blood sweat and tears,in it I will put my house for sale and see if I can buy it.also where did you get that roll bar for the back, I need one.
01JLH
Jed, I bought the complete roll bar package from Complete Off Road (or one of their associated companies). It came completely assembled and all I had to do was paint and install it. It has the interior as well as the exterior roll bars. The top can be removed without doing anything with the roll bars and one of the long bikini tops fit nicely over it for open air driving.
01JLH
Actually, the company name is Extreme Custom Fab in Dubuque, Iowa. They have
01JLH
complete kits that can be bought both assembled or in pieces.
01JLH
Look at item #330478097328 on ebay. Just enter the number in the search function and it should find it.
WheelHorse
You truck looks good, is packing the right equipment and should have no problem selling.
I couldn't quite tell from the pics, is she still packing drums up front?
01JLH
76- has factory disc brakes on front and big drums on rear with Hydro-boost power brake booster that will slide the big tires if you just think about stopping.
Blksheep1
Rome
I know this truck well and i can say with out a doubt there are no surprises in this bronco it is all jam up and jelly tight every thing bolt to bolt. This guy is a perfectionist and this is his baby I just wish I had the money
01JLH
The Detroit Soft Locker in rear and rear axles are 28 spline count.
01JLH
Surely, someone needs a real good truck. I have to many right now.
Status
