1976 LUBR build "Tina"
fishinman78
fishinman78
Sandblasted and ready for Line X and paint
1strodeo
Squirrel Watcher
Wisconsin
lookin good, bout what mine has looked like since August, except yours has a lot less holes %)
1strodeo
Squirrel Watcher
Wisconsin
That was a fast turnaround. You hear too many stories about shops sitting on the work as the easier projects flow in and out. Will they also be doing the paint?
^^^ This is me ;D guy does amazing metal work though
fishinman78
fishinman78
Put the last coat of paint on the frame and installed new stainless steel break lines.
JeffG
San Antonio, TX
Very nice! Are those pre-bent brake lines or did you bend yourself? If pre-bent where did you buy those.
I'm at that point on my build and did the frame rail lines myself, but I know that I couldn't get the bends that nice.
fishinman78
fishinman78
It's a pre bent kit from Inline Tubing I got it from Tom's Bronco Parts. It included all the brake lines. They are really nice.
fishinman78
fishinman78
Color matched Line X is done. Looking great!
Tugross302
That looks really good fish. Mine is in copper which is a little more translucent but I’m still happy with it
fishinman78
fishinman78
First coat of lizard skin is on!
Looking good. Can't wait to set the body back on the frames
fishinman78
fishinman78
I got the transmission cleaned stripped primed and painted today. I mounted the Bronco Hut cross member. I'm hoping to get it bolted to the engine and set in the frame in the next couple days
sprdv1
REBEL
Nicely done bud.. and "good luck" on that other endeavor ;)
fishinman78
fishinman78
I got the transmission installed today.
Need to get my transfer case bolted up and twin stick installed and the body should be ready to go on.
fishinman78
fishinman78
Transfer case installed along with JB Fab Twin stick
fishinman78
fishinman78
Aero tank installed. Need to install the pump and run fuel lines next
fishinman78
fishinman78
If you run the lines on top of the frame, make sure you can get to any connection points with wrenches once the body is back on. I made that mistake once %)
I was looking at that last night. I definitely need to figure out a safe place to run them
