Broncology
- Nov 19, 2005
- 905
'77 Bronco with a good body (does need some panels replaced) and por-15'd frame. I pulled the body off the frame and put alot of work into cleaning it up. The body needs some work but is a great start and better than most that I have seen. This bronco has a James Duff 3.5" suspension lift and a WH 1" body lift. The JD lift has approx. 200 miles on it. I have installed BCB Deluxe fuel line kit and stainless brake lines, it also has a new proportioning valve. I had started putting on the Explorer serpentine kit on the motor, but it still needs to be finished up and it needs a new distributor.
Replacement panels that are included with the sale (Brand new, still in box):
-Toms Dr & Ps floor pans
-Dynacorn quarter panels
-OEM rocker panels (graveyard)
-Toms rear wheel tubs
Parts NOT included:
-Front Fenders
-Transmission and transfer case
-Top
-Wiring Harness
Here is a link to my build: Half-cab top has been sold, as well as, the Mickey Thompson Wheels & Tires
http://classicbroncos.com/forums/showthread.php?t=179020
**The blue bodied bronco is the one I am referring to, green bodied bronco is no more.
I am sure I have forgotten plenty, let me know if you have any more questions.
Chuck
Parts NOT included:
-Front Fenders
-Top
-Wiring Harness
Chuck
