1977 Bronco: Victoria Project- UPDATED FINALLY
u10072
u10072
Updated Pics
Rolled Victoria outside. Just got the roll-cage in, dash, doors, fenders and my lite-bar bolted on. Probably update the thread better for the along the way pics but for now this is what its been up to. If you look at the original list I kind of blew that out of the water sorta :)
u10072
u10072
Fuse Panel/Glove Box
Blue Sea fuse panel, 12 fuses and has a nice cover to protect the fuses and also has 6 places for grounds as well.
u10072
u10072
Hey great minds think alike :)
Well the original piece that made to go around the factory glovebox opening was tough to get right, then the body at the top is really in the way, then the latch sticks into the comparment about 1 1/8th". Not wanting to scrap the whole thing which I might actually. In retrospect the new plastic liner with a support strap is probably much better choice.
u10072
u10072
Thanks for the compliment,,, I've gotta take some more pics...
Heus33
Yeah more pics! Love the stance and the wheel choice. And that light bar is MEAN looking!
u10072
u10072
Heuss33--thanks a lot. It actually sits pretty low truthfully 3 1/2" in the front and 2 1/2 in the rear with a 1"bl. That litebar turned out like I had hoped and is one of my favorite elements! Ive "liked" your FB page and would love to have a pair of your KILLER HID HEAD LIGHTS!! Thanks again and more pics soon!
u10072
u10072
Seat Brackets
The seat brackets are done this way so that you can get the seats as absolutely low to the floor as possible. To me a stout seat mount is important and gives the universal seat sliders a great place to mount. The mounts are so close to the floor - 1" access holes are made to tighten the slider mounting nuts in place. A simple OEM Ford grommet is then put in the floor to keep out the "stuff"...
u10072
u10072
Radius Arm Mounts
Here's a good look at the radius arm mounts. The centerline of the radius arm as it goes through the hole is lower -- netting a cheap degree or two of extra castor. That weld under the truck at an angle is tricky.
WheelHorse
I saw in your signature the Vintage Iron Fabworks...I was looking at the drop brackets and thinking that's a skilled worker right there.
u10072
u10072
Yea I have a pretty complete set-- an air/hydraulic press makes it all possible though.
Thanks on the radius arm brackets-- at some point I am going to be automated to some degree so I can make those with some speed. Now its just a template, bandsaw, hole saw, at least a couple hours. Then you all wont be stuck using the Poly Performance ones-- which dont fit properly on the frame (at the back) with 12" over arm.
BluebroncoNC
Asheville, NC
Um, wow to the description you just gave over the difference in a piece of metal. You have skills beyond mine to "modify" something to make it work. Can't wait to see updates!
u10072
u10072
Rear Shock Mounts
Rear shock mounts with FOA 2.5" -12" travel shocks - the 7/8" shafts on the 2.5" body shocks are just massive compared to a standard twin-tube or the anemic "Blisters"
u10072
u10072
Front Shocks
Here are some pics of the front shock mounts. Also shown is the cold air box and the bumpstop mounts.The lower radius arm shock mount is on the side of the arm so that the shock can actually go to full compression at the stock location. Also are pics of the front drive shaft -- this is showing the benefit of the HP Dana 44-- the pic shows the FOA 14" travel shock at full extension and the driveshaft still having room to drop out. The spring wont stretch that far but at least you know that your driveshaft will not be at anywhere near its max.
u10072
u10072
Battery Box Pics
Pics of the optima battery box- the box is one readily available for $35 but was modified to mount in the factory EB battery mounts. After the nutserts started to spin I took them out and just added a 5/16" stud so I don't have to worry about the battery bouncing around. In the 4th picture you can see the hood pin mounts.
u10072
u10072
Goal is for moving under its own power in about 30 days-- not finished just able to be moved that doesn't require me pushing :)
u10072
u10072
Flares
Got the flares on-- I might have used too many rivets but but I measured some rivot spacing i on some airplanes and on a couple Shelbys' and this was what I came up with. The good thing with more rivets is the "puckering" on the flares between the rivets you get sometimes when there are too few. One more thing marked off the white-board!
