1994 bronco donor?
slcpunk
The WB, UTAH
I am looking at a 1994 bronco that is for sale. It has been wrecked, but has a good engine and trans. The engine I know is a 5.8 351, but I only know the trans is an auto that has the overdrive button on the shift selector. So my questions are...
1. What trans is this?
2. What else could I use off this(other then engine, and trans)?
Trans should be an E4OD. Too big to work in an early bronco. Confirm this with a tapemeasure. Transmission pan will be about 20" long.
As for other stuff, depends on what you need, want, and are willing to adapt. Basicly not much.
Tires and wheels will interchange.
Tail light bulbs are probably 1157s
Seats should be modifiable (unless it is a bench)
SaddleUp
Vancouver, WA
slcpunk said:
so e40d trans? Is there anyway it is the aode?
91 looks like the last year for the AOD in the Full Size Bronco. 94 was a good year (94-96) for the 5.8 truck motors though as it should be a roller motor.
If the pan is 14" long it is an AODE, but don't expect to find that behind a 351 from the factory.
A friend recently had a '93 Bronco with a 302 and E4OD trans (I think that is the engine it had, it was a real basket case).
