This is a great transmission, as it is set up to work in a truck and has overdrive. It will work in an EB, but as has been mentioned you need some way for the computer to control it. If you plan to use this motor and trans, be sure that you also keep the computer and wiring, and all emissions controls and sensors. o2 sensors, and I believe there is a sensor in the gas tank...
