After cutting up the floor and fighting the 5 speed trans install I finally got the trans mounted to the engine. I should have checked the started bolt sizes when I discovered the 6 mounting holes were to small. I had just gotten the trans ready to bolt to the motor when I discovered this problem. Removed the trans and drilled those out so the stock bolts would fit through the bell housing.
My guess is the starter mounting bolts need to be metric. Any one know for sure what size they are?
For the record this is a 99 model 4.2 trans.
