2” body lift
gmduncan
Annapolis
Anyone have recommendations for a 2” body lift? Pros and cons of poly vs anodized aluminum?
Thank you and have a great Labor Day
CowboyGrin
the circus looks like fun
Oklahoma
Good question. I just pulled the trigger on the WH aluminum 2” body lift kit. Had a hard time trusting poly to last as long as aluminum. Was looking at the JD kit also but it was 50% more. No idea why, other than inclusion of clutch rod extension which I didn’t need.
gmduncan
gmduncan
Annapolis
Thank you…
The only negative for the aluminum that I can think of, is price. They cost more...
The vibration thing should be unnoticeable due to the existing cushion/insulator/mount that fits underneath it. So there is still an insulator, either rubber or polyurethane, even when using an aluminum body lift.
Madgyver
Bronco Madman
off subject. why would you want/need a 2" bodylift?
Lots of reasons these days. Both modern, and old.
gmduncan
gmduncan
Annapolis
As always, thank you Paul...
Madgyver
Bronco Madman
Installing a GEN3 Coyote and a 10r80 trans, 3.5" WH lift under a new uncut tub with 35"s
Has anyone tried to lower the coyote motor?
clearance whatever it needs to keep low center of gravity.
CowboyGrin
Oklahoma
My reasons were transmission too but also for an Atlas t/c. Coupling with a 2.5” suspension lift to run 35s.
duffymahoney
Badass bronco does a 1.5" body lift for their broncos and coyote swaps, and they are using my 1" bumperlifts, which are technically 1.33" in the front. Looks about perfect with stock bumpers.
Johnnyb
Flagstaff
I put in 2" poly in 2005 and they have heald up well. I did 2” to get a 23 gallon tank and ground clearance. Also helped with EFI, Explorer PS. I didn't think I wanted a body lift until the tank, now I don't know how I lived without it.
JB
