2 quick wiring questions
Gator809
A small town
When I bought my truck, it had dual tanks swaped in, but didn't have the dash mounted switch wired in at all. I have a stock switch, but I have no idea where the wires go on it.
The terminals look like this on the back:
1 2 3
l \ l
l l l
4 5 6
Where do the main tank, reserve tank and gage wires go? Is there a ground wire at all?
I am in the process of re-wiring the truck with a centech harness. I am going to reuse my stock wiper switch, which has the 7 wire connector. I looked at Lars tech article about using the stock connector, but Centech has since changed the harness. They now don't mention anything about changing the wiper motor, and the wire colors have changed.
I've figured all but 2 of the connections out, high an low speed, washer and 12v power were easy. I have the "Park Power" and "Motor Stop" wires left on the ford connector, according to Lars chart. I now have 2 wires on the centech harness left, a red wire "return" and a black wire "park".
The obvious seems to be connect 2 park wires together, but the bumbling electrical idiot in me says to get a second opinion, and the guy @ Centech really didn't seem to know what he was talking about. He suggested to just hook wires up , the worst he thinks I could do is blow a fuse.
B
bert
Guest
Can't help with the centech question.
As far as the fuel tank switch goes: the dash mounted switch only switched the gauge, not the tank lines. The tank lines were switched by a manual valve located under the drivers seat. At least that is how my 71 was.
The center terminal on your switch is common to either terminal on the side of it and make contact with only one side or the other depending on switch position. If switch lever is to #1 then #2 and #3 are hooked together electrically. If the lever is ot #3 then #2 and #1 are hooked together electrically. #2 is wired to your gauge. #1 and #3 go to your tank sending units.
You will need an electric fuel switching valve if you only want to use one switch. There are several valves available and they all work a little differently. Wiring would be specific to the particular valve you are using.
