200 straight 6 ticking!
Betsybronco
Hi I'm new here I have a 1967 bronco with a straight 6 200 it's freshly rebuilt and it has a tick I put a second new set of lifters in and they are adjusted properly. They are hyd. And thoughts? The tick goes with the rpm and I'm possitive it's not an exhaust leak
bmbm
check out the fordsix.com forum its all they do.
Pa PITT
Stephenville TEXAS
Funny you said the fuel Pump...... Years ago many years ago I saw a 6 cyl chevy 292 replaced under warranty. For a fuel Pump that had a knock in it.
.. YOU Got to hate it when that happens . And that was the GMC dealership...
Scott C.
Waynetown IN
I thought that the 200's did not have the adjustable rockers? The 170's did but they were solid lifters. Exactly how did you adjust them? Did you do it hot, or cold? What procedure did you use? Replacing hydraulic lifters and not the cam shaft is risky. Is the cam shaft new?
half cab
Guru Bronco
What about the fuel....I have to add oct.boost to my old 351w for it not to tic with this poor fuel we are forced to buy.
TwoDalesDad
I had a289 once that a guy was helping me get running . He kept tellin me that we had to adjut the lifters...and they were noizy as a bitch. Clackityclack...he would adjust them some more and some more...I threw in the towell and called time out........THE STUDS WERE PULLING OUT OF THE HEADS...THE PUSH RODDS WERE TOO LOONG....I DID END UP WITH A HYPER TWO EIGHTY NINE...BUT.....I DID HAVE A HUGE TICKET AT MY MACHINE SHOP....
B
Betsybronco
The rocker assembly is new and it is adjustable I don't remember if the old one was but it was worn out. It has a new rv can and I adjusted them while it was running, I loosened them till they clicked, took them down to zero lash and went 1/4 of a turn then waited for the lifters to recover and then another 1/4 turn each time the engine stumbled because the valves were opened but they after they recovered it ran smooth but still clicky. I adjusted them with the engine warm to operating temp. I don't know what else to do the sound is coming from the valves somewhere. And everything in the engine is new. I even pulled the plug wires while it was running and no change. The sound is constant and stays with rpm and doesn't change under a load. I have 50 psi in oil pressure so I dont know what to do!!!
Scott C.
Waynetown IN
Did you rebore the cylinders and replace all the pistons and wrist pins? Some times a loose wrist pin will not make much noise until you put in new rings and increase the friction and compression. Then they can be very noticable.
Is it a clicking sound just like your lifters when you adjust them? Or, is it a knocking sound? If so, does it knock once or twice everytime?
Have used your stethascope all over to eliminate all other moving parts? Even the alternator, water and oil pumps?
I assume the timimg chain is new also?
When you adjust the rockers and the ticking comes back, is it always the same valve? If you adjust it tighter, does the noise stop and then return later? And if it does, can you just tighten it more and it stops? If so, you are losing a lobe on that cam. I have seen them go in just a matter of minutes of run time.
B
Betsybronco
Everything is new and yes it's bored 30 over new pistons and rings wrist pins and rods. It's hard to tell what valves are making the noise but even when I tighten them up the noise is still there. I check the distributor, fuel pump alternator water pump PVC valve everything
Scott C.
Waynetown IN
Have you tried adjusting the valves cold and with out the engine running?
Did you replace or knurl the valve guides?
Are the vavle springs new? Or, where they checked out?
B
Betsybronco
I tried adjusting it cold no difference. I don't really know anything about the head but new guides and valves were put in. And yes the springs are new to match the cam
Scott C.
Waynetown IN
Just to eliminate and to be sure. Check the crankshaft for end play. I have seen several of these small inline Ford 6 cylinders that some one put the thrust bearing on the rear main and it belongs on the center main. That lets the crankshaft float back and forth. That will cause a noise too.
I would assume that they repaced the valve guide seals and not the valve guides them selves. They are cast into the head and require machining them out and pressing in a replacement. If a valve guide is loose it can cause a noise too. It was not uncommon to have to replace all the valves and guides and rockers and shaft due to excessive wear on these engines back in the day.
Another common problem on these was that the head would crack from the carb base down and around through the exhaust port. Some times almost completely. That would cause a clicking sound, it would really be an exhaust leak, as well as a vacume leak.
And speaking of exhaust leaks, make sure that your exhaust manifold and the surface on the head are both good. These things are notorious for cracked and or warped exhaust manifolds. Did you put an exhaust mainfold gasket on it? Or, did you just bolt it against the head?
B
Betsybronco
I swear it's the lifters did I adjust them wrong? I went to zero lash and then 1/2 turn?
