Jmjuhl
City:
Cypress
Price: $ 7500
Price: $ 7500
Sold my rolling chassis and need to let the engine/trans/control pack go. Great starting point for a coyote swap.
Engine is a 5.0L Coyote pullout from a 2016 Ford Mustang. Estimated mileage is 100k when it was pulled. I removed the heads, cleaned the carbon off the pistons, and cylinders still had crosshatch. Installed new head gasket, cleaned up the heads, and installed a set of Comp Cams “Mutha Thumpr” cams with ARP bolts. Everything torqued to specs in Ford Service Manual. Installed GT500 valve covers and MMR oil pump and oil pump gears. It comes with 8 new coil packs, spark plugs, and engine harness. Also have a Gen 2 or Gen 3 intake, let buyer choose which. Has KMF stainless headers, KMF oil pan installed, and BC Broncos motor mounts.
Trans is a 6R80 with 15k miles from a 2015 F150 4x4. Trans filter has been changed and I have a case of Motorcraft trans fluid that goes with it. Includes factory torque converter.
Asking $7500 located in NW Houston. May consider parting it out later but would prefer to sell as a package. Motor is on an Eastwood rotating engine stand and will let that go with the sale for transport.
