    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
AR 2020 OCBR Parts for Sale, Swap, Trade
Status
Not open for further replies.
stout22
Athens, AL
I have a big bearing 9" housing that came out of a 76 Bronco. This is just the housing. No shafts. No 3rd member. It's a little crusty on the outside but clean on the inside. I can get pictures if anyone is interested. Make me an offer I can't refuse;)
JWMcCrary
Duff long tube headers, Flowmaster hushpower mufflers, complete exhaust. You would need gaskets and bolts for the collectors and a couple of hangers. The tailpipes stop short of the rear bumper. The pipe between the headers and mufflers have a up bend in them to clear the crossmember for duffs torque tamer, if you don't have that it doesn't matter, just an extra bend in the pipe.
Mufflers and pipe are 2.25"
The mufflers alone are over $100 each new, google it.
I'll take $125 for all of it and deliver to OCBR.
If you are interested in just the mufflers or just the headers make me an offer. I can cut the mufflers out of the pipes if you just want the mufflers.
I'm not hauling anything that hasn't sold before I leave, there is good deal to be had here.
bchesley
I have an almost complete suspension kit I can bring if anyone is interested. Its a lightly used 5.5” all spring lift kit. The coils and leaf springs are Wildhorses and includes the 6 degree shims to properly set the rear pinion angle. Included with the kit James Duff drop steering arm and an extreme track bar drop bracket. Additionally there are two sets of radius arm bushings, 6.25 and 7 degrees, to dial in the front pinion and steering angles as well as extended front bump stops. All that’s needed is brake lines and shocks. Asking $750 or best offer.
Photos are found at this link.
https://classicbroncos.com/forums/showthread.php?t=304294
JWMcCrary
NP435 setup - $450
Transmission with adapter for Dana 20
Bell housing and motor plate
Throw out bearing - new in April
Flywheel with bolts
clutch & pressure plate with bolts
Equalizer Z bar, Frame pivot bracket, Clutch adjusting rod (all bolts)
new bushings still in package for Z bar
Tunnel cover plate and shifter boot
Hand throttle with intake bracket and carb attachment
Excellent condition, was just removed from my 75 a few days ago.
Trans shifter has JB fab black billet shift knob.
Flywheel could use resurfacing but was working fine. Clutch and pressure plate came from one of the Bronco vendors and was a heavy duty,etc, can't remember exactly, it was purchased years ago and installed but not run until 2017, has a few offroad trips since then. I would not hesitate to continue using.
I'm open to an offer delivered to OCBR.
1966tiger
I need a really good hardtop. One that needs to be restored is ok as long as the top section or drip rails do not need to be worked or replaced.
JWMcCrary
02 Sensor bung that clamps on to exhaust. This came with the 2V sniper kit. You drill a hole in the pipe and then clamp this on, no welding. It works fine and I used up until switching out my trans and needing some exhaust work.
$10 if somebody wants it.
Ether
Tulsa
Anyone have a console that will fit in a 1/2 cab?
joe
ISO...
EB Dana 44
Bare, complete or in between.
Banjer Picker
-Duff Power brake angle bracket. Vacuum booster not included $90
- Saginaw power steering bracket for explorer front dress
- York compressor mount bracket for Explorer front dress
- Beadlocks - Marsh racing. Heavy duty. 15x8 $300
- Corbeau Baja seat. Gray never used $90
- Oil pan - OEM for Bronco 302 $45
- Duff 4.5” progressive coils $75
- Duff front shocks for 2”-4” lift (only used 1 trip at OCBR last year) $50
- 2 Bilstein 5100 for f-250 or dodge w/ 2” lift $100
joe
Ocbr
PM sent for the seat
Banjer Picker
I have an extended clutch rod for a 2” body lift. $10 or a burger at the pavilion. ��
JWMcCrary
No pic but I have an explorer power steering pump that is used but good, I ran it for a while before swapping in another upgraded pump. $10 or buy Brandon another burger....he looks hungry
Prizefighter
I have some new in box axle wedges from WH.
A few speedos
Passenger seat
Rear seat that rusted where it bolts to the floor
Status
