ERLYBRONCKILLER
does anyone know if there is a way to mate a dodge 203 range box to a d20 without the expensive wild horses adapter?
Thanks EBK
Thanks EBK
bax said:you could use someone elses expensive adapter. you need the adapter kit to make it work.
bax
bax
I forgot to add. I don't need the 435 to 203 adapter I already have that. Just the 203 to d20 kit.ERLYBRONCKILLER said:How much does jeds charge for a whole kit? I have a dodge 203 range box in route right now. I don't know if it has the output shaft but it better. Also how much does jeds charge for an adapter if he resplines my shaft? Thanks for all your help. EBK![]()
ERLYBRONCKILLER said:I forgot to add. I don't need the 435 to 203 adapter I already have that. Just the 203 to d20 kit.
I haven't got the 435 yet. I have a guy who is sending me a dodge 203 range box with an adapter to mount it to a 435 so I figured Id wait to see what splines i'll need once I get it. I hope that all I need to worry about is the output spline on the 435 because I know dodge and ford 435s will work in the bronco I just don't know wich ones yet but I do believe this will work. I just emailed jeds to see about the 203/d20 adapter so I guess I will wait to see how much they want.Past_Miner said:Does your 435 output shaft have the correct splines for the Dodge 203 input gear? The WH kit includes a resplined main shaft for the 435 that fits into the Dodge gear. I don't know the spline count of the 435 off hand, unless it is a 4x4 version. If that's the case it will be 31 spline and you will need the input gear from a ford 203. Also, a Ford 203 will bolt directly to that transmission. I think the Dodge gear requires a 23 spline input shaft, but don't quote me on that.
I was being a wise ass earlier about making your own adapters. The only reason I did it was because I have a ZF5 and WH wouldn't split that main shaft out of their kit at the time. My friend has a 435 in his rig so the whole kit was required. It's a quality product that I would recommend if you have the 4x2 435.
ERLYBRONCKILLER said:I haven't got the 435 yet. I have a guy who is sending me a dodge 203 range box with an adapter to mount it to a 435 so I figured Id wait to see what splines i'll need once I get it. I hope that all I need to worry about is the output spline on the 435 because I know dodge and ford 435s will work in the bronco I just don't know wich ones yet but I do believe this will work. I just emailed jeds to see about the 203/d20 adapter so I guess I will wait to see how much they want.
crawln68 said:I would call and talk to Jon. He is a really nice guy and will explain everything to you. www.jedsmachining.com. Tell him that Patrick from CA says "Hi".
I called and talked to Jon and he said he never messed with the 203 to D20 only the 203/205 and 300. Did you have him respline the 203 of yours for the D20 or 205? He told me he doesen't make any adapter for the d20 at allcrawln68 said:I would call and talk to Jon. He is a really nice guy and will explain everything to you. www.jedsmachining.com. Tell him that Patrick from CA says "Hi".
I tried to get him to do just that but he doesn't think there is enough demand%) O well looks like i'm stuck buyen the hi $ WH adapter. I think I'll try calling AA to see what they can offer.crawln68 said:Mine is the 203/205 and I had him respline the 203 shaft to fit the 205 input. I wonder if he would make the first D20 adapter for you? Then he could market it to us in the EB crowd.
Same here......crawln68 said:I had Jeds respline my 203 shaft and I bought the 2 adapters from him too. He's a great guy!
Keep in mind that if you do a 203/D20 you will need to beef up the output shaft of the D20 and that's another $400.ERLYBRONCKILLER said:I called and talked to Jon and he said he never messed with the 203 to D20 only the 203/205 and 300. Did you have him respline the 203 of yours for the D20 or 205? He told me he doesen't make any adapter for the d20 at all![]()
