23 Gallon Gas tank Install Help
Jamoaus
Hi everyone.
So i got a 23 gallon tank from TBP and started the install fine, however when mounting, it seems there is little to no room for the exhaust pipes running to the back,.
I’m curious what people did to resolve this issue? Did you reroute the pipes? Any pics would help.
Any help / guidance would be appreciated?
Chief Master Sergeant
Retired U.S. Air Force
I ran into the same issue. Had to cut a section of my exhaust off. It's headed to the exhaust shop next week for rerouting.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I too had an exhaust system that worked fine with a stock rear tank, but had to be modified in order to install a 23 gallon tank.
gnsteam
Lincoln NE
I have a few pictures of what I did to get around the TBP's tank. Look at my build thread (link in my signature below) page 18. Starting at post 349 - 355. Note the driver side picture of the tank and exhaust in post 355. Instead of using the factory tank strap hanging location. I opted to drill a hole in the frame. Straight up from the tank strap. Then I usd a piece of threaded rod into the frame with a self locking nut inside the frame and another nut on the outside of the frame to fasten the rod to the frame. This arrangement gave me a little more room for the exhaust. I did the same on the passenger side. I also fabricated my own exhaust hangers.
njy229
Newbie
Here are a couple pics.
