G
Guest
Guest
I just purchased an aftermarket 23 gal gas tank from James Duff and have a few issues. <br><br>1) It appears that the gas tank strap bolt does not fit into the drivers side frame rail. Do I need to enlarge the frame hole? If so, what is the best method to do this? 2) When splicing the old sending unit wires to the tank, do I simply put both sender wires on top of each other on the sending unit screw ?. 3) What do I do with the evap lines ? I don't think the old tank had them?<br><br>All help is welcome. I just purchased a 1970 Bronco a few months ago and am still feeling my way around it. My goal is to have it running by spring.<br><br>Thanks ?:?
