Wild
I have a 1698 Bronco with a 289 - I have a couple of questions:
First the Factory 289 Heads are not able to be rebuilt so I am wondering what I have for options. Not necessarily looking for horsepower or anything that has any bling to it, as the truck is still stock and sporting its original paint (3 On The Tree - 3.03 Trans)
Pricing out new heads I found that there are cheaper aluminum options over the cast ones offered, but is there a newer head that would be a plug and play off a 5.0L that I could get rebuilt. I am still running the 2 barrel carburetor, stock manifolds, I am thinking of upgrading the cam shaft when I put it back together. I am looking to keep the stock appearance but want something reliable.
The Block is a 302 C8AE-6015 with 289 Heads
My second question is the bracket that holds the alternator seems to have room for another bolt on item. What was bolted to this bracket?
Thank You
Thank You
