- Aug 27, 2001
- 5,147
Could t find my old post so here goes an update. 71 stock Bronco. In my other post.....Had problem starting after running it. Fuel boiling in carb, Flooding, etc....well it’s not flooded since I put the 1/4” heat spacer in. So it’s 2bbl motorcraft with 1/4” heat spacer, new water pump, new radiator, timing set. Sometimes it still acts like it doesn’t wanna start when hot. Pretty common with this Bronco so I do the half pedal thing and she fires right up. I noticed the other day after 30 min of driving that the clear aftermarket filter just before the carb had a few bubbles in it so I felt it and it was hot and fuel seemed to be slightly boiling. I checked fuel line to see if it was close to the exhaust anywhere and it’s not. Any more ideas?
Thanks,
Blue71
Thanks,
Blue71
