More than likely you will need something to get your drag link and track bar parallel. You could try it with the stock pitman arm and see how bad the bumpsteer is, but I think you'll find you'll need something to compensate. If you ever intend to go TRO then I would recommend doing a track bar riser (Kiser Riser or WH) instead of the drop pitman.
