i've got a 72 reman'd 351w block (92'). have a 4 core rad new in 92, and holes in the hood scoop for venting. i've always had cooling issues when it gets hot, even just on hiway and city driving, mainly city when i'm low speed or idle.
just did a new water pump, new 6 blade flex fan (replacing stock 5 blade), new balanced 180 thermostat, new 50/50 coolant, and Walker949's cooling mod to the manifold (only i used two 1/4 " hoses instead of 1 3/8"). cooling is better but still steady at 190+ or up into the 210 mark intermittently.
I've talked to other guys running hot 351s and can stay at 170. so, this got me thinking:
1. i'm running the 302 water pump. is it possible this makes a difference?
2. the radiator is setup for a trans cooler, but i run a manual, so its empty. so could that affect the cooling (seems impossible to me)?
3. did different year blocks have any internal differences that could contribute to this?
4. lastly, my inner fenders are uncut, but have most guys cut them to get more air flow, which has made the diff.
