...OK any of you guys Replace the 1BBL on the 300 cid's With your 2BBL Motorcraft.
.. I know a lot of folks seem to use the New Holly 2bbl 4100 ''I THink'' . I believe it has 350 or 400 CFM.
. I don't new a bigger carb on my 300cid I just need a carb to run correctly.
.. I got to thinking that the old Motorcraft 2100 I had on my V8 I pulled out for my Diesel swap . That old carb ran good & I still have it.
... So I got to thinking of buying a 1 too 2bbl, adapter & Putting the Motorcraft carb over on my 300 cid.
... So I expect If I GOT THE CARB REKITED & MOUNTED UP , It'd run ok but What do you do for linkage . I have a throttle cable But I believe the Linkage on the carb will be ON THE WRONG SIDE OF THE CARB.
... DO YOU KNOW IF THE Bracket for the Pull cable in home made or is there one to be bought .
.. My Throttle cable comes from later model fords like 80 to 86 6 cyl & connects to the foot peddle.
... Hope that makes since.
