Progress! I ended up drilling 5 tiny holes around the EZ-Out... Then connected the holes by drilling with the side of the bit (you know you have all done it!), and the EZ-Out came out with a needle nose pliers. Then drilled the remainder out with a 7/16 bit. Then tapped with 1/4 NPT tap. Then fished everything I could out with a telescoping magnet. Then used the vacuum idea... sucking out about a quart to make sure I got all the loose pieces. Fired it up without the radiator (C4 Pumps
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
). Walla! Oil pressure!
Thanks for the ideas guys!
I plan to change the oil and filter several times after putting it back together. Might even splurge for one of those magnetic plugs and or filters. I think after about 1000 miles I'll feel better about getting every last shaving!
