302 coolant overflow bottle
hodge's 69
I recently insatlled an overflow container for my radiator. My question is this, if the stock radiater cap is 13lbs once the pressure is built up pushing the fluid out into the container once the engine cools off how does it suck the fluid back in? I am asking because my container will fill up but nothing is being sucked back in. Any help would be nice. Thanks-Ty
Jeepster
If its the stock container the over flow hose must be long enought to rest on the bottom of the container so that its allways submerged in coolant, otherwise you will suck air back into the radiator.
H
hodge's 69
The bottle actually has the hose from the radiator going to the bottom of overflow bottle and a hose out the top for drainage out.
Stock cap has a single rubber seal on the spring to make the pressure. Water gets past the seal into the spring area and out the overflow spout.
When it cools it sucks the water back and pypasses the spring through another port that most don't even look for.
Now the key, on that sucking the cap needs to seal at a different place then when it pressureizes. There is a rubber seal at the sheetmetal on the top of the cap. The gasket is only there on recovery systems. On non-recovery systems the gasket is just extra cost and not needed. If there isn't a gasket there it will suck air and not pull water back from the overflow.
Also the overflow needs the hose connected to the bottom in order for it to recirculate correctly. Sucks up like a straw.
barronj
Mine has two overflows- one off the mini tank on the return, and one coming from the nipple off the radiator.
If I'm running power steering, is it ok to ditch the mini tank?
deltarat
Drew,Ms
The tank I got from JBG only had one place for a hose. I ran the hose from the radiator to the bottom. I guess if the tank fills up, it will have to run out the top.
pierr
Gordon,GA
Coolant Overflow Bottle
Is it possible that you have a hole in the rad. somewhere & it's sucking air at that point, rather than sucking the coolant back into the rad. after everything cools down? Had this to happen on a Mustang I had & drove me bonkers 'cause it was just a pinhole & didn't leak enough to notice anything under the car. Just food for thought:)
cgbexec
Naples, FL
When your engine is cool, there should be just about an inch or two in the overflow. As your engine heats up the coolant expands and flows into the overflow bottle. As your engine cools, it should suck the coolant back into the radiator. The fluid will find the proper level after a couple of heat up/ cool down periods.
When I first filled my system, my overflow bottle overflowed. After a few days of driving the Bronco it found a level. After a week or so I popped the radiator cap (when it was cool) and noticed that the coolant was down in the radiator a couple of inches. I topped it off and now when the engine is cool, the coolant level is on the low/fill line and when the engine is at running temperature the coolant level is at the hot line, which is perfect!
