302 to 351W accessory fitment problems
cheesenip73
Before I swapped out the 302 to a 351W I had a York compressor (mounted flat on the passenger side above the alt) and a 3G Alt. Now I cannot fit the 3G in the alt bracket that was on the 302. I already know that the bronco houses sell the little extensions for the PS and Alt brackets. I used the PS off the head and it works great. But, becuase I have the 3G it extends it out to far making it run into the inner fender well. Problem, no tensioning aspect. Should this get fixed the old 302 bracket for the york will not allow the 3G to be under it. How and who has gotten all of the goodies back on their 351W's. As of right now I'm just running the old stock 55amp alt.
I need my OBA back on and a higher outputting alt for my new warn winch!!!
ROKDWLR
Stockton, Ca.
Maybe you should wait until the next Bronco event. I'm sure you'll win the bracket then, you lucky dog! J/K. Is that TRO installed yet? I don't know the answer but I saw Scott from American Bronco's 351W/York setup at the 40th and his was over the PS pump. I bought a similar setup from Patrick on the way home from the event. Just need to find or make a bracket for the PS pump. Maybe he knows where to find another one? There is also a thread in the tech section about that version. Good luck.
