33X 12.5'S On a 1966 EB with a 6cly ?
coupe66
Cedar Park Tx
How would my 66 EB with the original 6 cly and 3spd do with 33x12.50x15 mud tires ? I have 355's for gears .
okie4570
NW OK
I would want lower gears for sure. What are you wanting to do with it?
I can already smell the burnt clutch.
What are you doing with 3.50 gears and a stock 6-cylinder? Stock gears should be 4.11 and optional 4.56
coupe66
coupe66
Cedar Park Tx
It originally had 411's but i swapped out the stock Dana 33 for a dana 44 with disc and the original rearend with 411 gears were toast so i swapped them out .
Whats the biggest tire i could get away with .
bsquared
I had the original 170 in my 70 with the 4.11's and stock tires and had little power to spare. I'm looking to move up in tire size now that I have a 5.0L, but I wouldn't expect squat outta my old setup with 33's. (and that's still talkin 4.11's)
I've got a lot of info on the 96 Exploder swap, if you're interested. ;-)
Best of luck with the work. Cedar Park is nice. There's a "Bronco" car wash about 10 miles West of you in Lago Vista. (my Dad lives there) Corner of First and Bronco, of course!
Cheers, B2
coupe66
coupe66
Cedar Park Tx
Cheers, B2
Those are some cool pics of the bronco and car wash .
The only reason i was thinking about 33's is that i also have a 72 bronco that i'm fixing to sell and i thought i would keep the 33's on it for my 66 bronco being there like brand new and my 66 needs tires .
Robert
xcntrk
NOVA
Doesn't the 6cyl 3-speed have taller gearing than the 8cyl 3-speed (RAT vs RAN)? That would make it ever worse with larger tires.
wildbill
Old Bronco Guy
:cool::cool::cool: It will run down hill ok. You need 4;56's with a little six and even it wont be grate good luck and think about a 351W will make you a happy camper. :D:D:DBill :eek:;D%)
75junebug
NW Houston Tx
Keep the 170 6 banger. Find a carb from a 200 sixer and install it. Go 456 for gears and you will be able to handle most any situation.
bmc69
That. There was a very good reason the truck came with 4.11s to start with....;)
My '69 daily driver did OK with the stock 4.11s and 35s, but the 170 was replaced by a '78 250 I-6.
RolledItAgain
If you already have the wheels/tires I'd swap them on and take it for a drive. As others have said... find a hill and see if you can get over it at a reasonable speed.
33's will look better. :)
bmbm
170 six
Don't know if this will help you but for performance info on the six go to fordsix.com they are the experts. Good luck.
coupe66
coupe66
Cedar Park Tx
Not very many big hills in my area so i would probably be ok. if worse came to worse i could always swap out the gears to 411's again . I just think its worth keeping the new wheels and tires for my 66 and not let them go on the 72 i plan on selling . ;D
