...what the others wrote. The longer shaft is needed to run a Windstar cam synchronizer in a 351W block with an adapter. That's because the adapter places the synchronizer gear in the correct spot to be driven by the cam, but then the end of the synchronizer shaft is too high in the block to fully engage the oil pump drive shaft. The longer (351C/351M/400 is the spec) solves the problem. Just dumb luck that an easy to find OEM spec part worked out perfectly.
