351C Power Streering Bracket
GrillMaster
Taking off my AC and selling it (see classifieds). I need to find a power steering pump bracket so I can remove the whole unit. Where can I find one?
I thought (and am probably wrong) that the face of the clevland head and the windsor head were the same. The 3 bolt holes that the accessorys bolt to anyway.
bax
Old Member
Use the stock 400 PS bracket and for the A/c use the vintage Air bracket they sell for the c motor
Desert Thrasher
If you want a saginaw pump, look for a large ford car, like an LTD or lincoln whatever, with a 351m or 400. Its what I used before I switched to the March aluminum bracket set.
TexasBronco
Waterford, MI
I looked at the March set up, and emailed them looking for a kit that just has the Water Pump, Alternator, and PS pump mount. Also any idea on a price range?
Pa PITT
Stephenville TEXAS
if you don't find one ask me next week I'm almost positive I have one I bought that was supposed to be a 302 but it was a half hole off.. It's just a fraction larger than the 302.I'll try an look in the shop this week end ..If I have it I'll just mail it to you PM me an address ..If you find one else where get it I think this one will work with a Sag pump ..Which is a must have..
Pa PITT
Stephenville TEXAS
Ok I found the bracket ..It says it's for a 302 painted on it but it didn't fit my 302 ...Do you need any of the pump brackets.. I have one of the alumin bracket for the ford pump.. I couldn't find my home made bracket for the Sag pump ..I didn't think it fit good enough ,So I order a set from WH and they were just barely better than my home made ...
Let me know and I'll mail next week..
GrillMaster
GrillMaster
not sure what type of pump I have. Will try to take a picture tonight and research/update. Thanks!
