351w cooling ?
eb-nutt1
Have a friend with a 351w in a eb truggy that has severe cooling issues when it gets above 70* outide. Things he has done: aluminum radiator, taurus fan, bc's high flow waterpump, changed heads and gaskets. Don't know alot about the motor build but from listening I would say it's basically stock, even has exhaust manifolds. Has no inner fenders. Runs around 190/200* along as the temps are 70* and below but anything above causes temps to hover around the 230 and above range. Any suggestions?
SHX669
How big is the aluminum radiator ?
Does he have a fan shroud?
Will the fan hold a piece of paper against the grille at idle?
Has he verified the temp is actually 230* or is that what the gauge says?
SHX
bronconut73
I have similar issue. But only in street/trail traffic. While moving it's fine.
Subscribed. Help us out cb fellers.
SteveL
Huge chevy guy
Hawthorne ca
Both my 351w's run a standard bc 3-core copper radiator with stock napa pum and manual fan. they run way cool in LA traffic. Sometimes those high flow pumps keep the stat from opening causing cooling probs.. Went thru it on my 72 suburban. Went back to a stock pump and all was fine
E
eb-nutt1
radiator is a standard eb size with 2 cooling tubes, no shroud other than what is around the electric fan, , fan runs anytime engine is running, and don't know if temp has been verified other than the fact that it has had two(brands) different manual temp gauges tried.
Ourobos
Big Island Hawaii
Normally if it gets hot when going down the road, it's a flow issue.. If it stays cool moving but hot when sitting, it's an airflow issue. I'd look into a shroud for sure either way.
