Jmjuhl
I am slowly researching/pulling together parts as they pop up for a 351W EFI build for my 74 project. So far I have a line on a complete 5.8 motor/wiring harness/pcm from a 96 Bronco in decent shape. I know they were OBDII and mass air but electronics less desirable because of added emissions stuff in the pcm.
I have also had a GT40 Lightning lower/fuel rail combo sitting around and an upper from the 95 Mustang Cobra R which came with the limited 351W models. For all intents and purposes it is just like an SN95 Cobra upper but with the 5.8 badging cast into it…but also with the 45 degree elbow vs the 90 degree on the Explorer and Fox bodies. I know it may complicate the throttle linkage cable a bit as well as limit Throttle body/mass air selection possibly. The added benefit is it's slightly lower profile than the Lightning tubular and gains about 1/4-1/2” of hood clearance vs the other uppers.
Looking to build a warmish 351 with mild cam and 165ish AFR heads, or something similar. Probably 24 or 30lb injectors. Goal is 350ish HP. Will also run Explorer serp setup and leaning towards an AX15 or Tremec 4050 5 speed.
So here is my questions:
I am intrigued by the Explorer EDIS setup and know I will need to figure out the cam sensor…could Explorer efi be made to work?
Does this SN95 upper with 45 degree elbow complicate it, or make it not usable.
Which wiring harness/PCM?
With the Explorer/Mustang electronics getting up in age warrant looking at an aftermarket efi setup like the Terminator X, or Megasquirt?
