- Apr 28, 2017
- 447
I just bought a brand new Ford racing SVO GT40 Crate engine.
It is an older motorsports product M-6007-B351.
It is a F4TE roller block but it has a hydraulic flat tappet cam installed (specs below)
It is 9.0 compression
GT40 iron heads
Hypereutectic pistons
SVO Marine long block
Cam is M-6250-A335 .491 Intake/.509 Exhaust 220/230 duration installed on a 107 center line with 112 lobe separation.
Edelbrock Performer RPM Intake
Aluminum Motorsports valve covers
Water pump
Timing chain cover
Electronic Distributor
Rated at 346 HP @ 5750 RPM, 364 Torque at 4250 RPM
You can see the thread when I was thinking about purchasing here
http://classicbroncos.com/forums/showthread.php?t=287634
I am going to run Fitech on this. Probably without timing control for now so i can use the Duraspark distributor that came in the engine.
I am trying to get this installed on a bit of a budget.
Part of me thinks I should just drop it in and go. I would assume that the distributor and all associated parts are all set up for the heads, cam, etc to maximize power for the application.
The other part of me is worried about the size of the camshaft for the application. (granted I really don't know a whole lot about cams). Is this too much cam??
I have a Explorer 5.0 on a stand and I could grab the roller cam, lifters, spider out of it and install it into this engine and it won't really cost me too much or maybe I should think about upgrading to a little better roller cam. I would prefer not to mess with valve springs, push rods and all of that if possible.
I am running a C4 Auto, 4.88 gears, 35" MTRs
I just can't decide. Looking for opinions/advice
GT40 iron heads
Water pump
Timing chain cover
