351w Valve Cover Options
greatguy57078
I have a '69 351w engine with new Ford Motorsports GT40X aluminum heads. I also have the Ford Racing 1.6 rockers installed. I am running a carb to start out with, but would like to go EFI sometime down the road.
I would prefer the new style Bronco script valve cover, but I have been told that they are not made to fit my application. Is this true? Every vendor site I have been to shows these as 351w compatible. Is there any reason why they might not work for me?
The vendor that I spoke with told me that I would need the 351 covers, and that they don't make the Bronco script covers to fit my application. I am a little confused....I guess? %)
Any thoughts or suggestions?
broncnaz
They will fit sometimes the baffles need to be modified to clear certain roller rockers. 302 and 351's use the exact same heads only real differance is the head blt hole size. So your vendors info is wrong. Your only issue may be when you convert to EFI. As usually they wont fit due to manifold height. Might have to use a spacer between the manifolds to keep your valve covers.
75junebug
NW Houston Tx
I think it all has to do with the internal baffles on the valve covers interfering with the roller rockers. Ours was an easy fix, modifye the baffle for clearance. Unless you are running some funky intake, I cannot see interferance issues with the valve covers. I have had stock 2BBl, performer 4bbl, offenhaouser 4bbl, and 5.8 truck EFI manifolds on mine over the years, and never had an interferance issue in that regard
greatguy57078
greatguy57078
I have been reading the info and it sounds to me like that have modified these covers other then to fit under some EFI plenums.
These Ford-approved, officially licensed valve covers feature the original Ford Bronco script design. These valve covers are made from high pressure die-cast 383-3 aluminum-alloy zinc. They feature improved oil baffles and are specifically designed to work with both standard and high-lift cam shafts, as well as many types of high-lift roller rockers without any additional modifications. Finished in durable black wrinkle powdercoat. Includes rubber grommet, oil filler tube and spark pug wire brackets. Made in USA. Fits 260/289/302/351W. Note: may not fit under intake plenum of some EFI-equipped engines.
