I pulled a 351 Windsor roller motor from a 1995 E350 van a few years ago to run in my nice frame off 77. I pulled this motor because the van had rolled over before it wound up in the junk yard so I pulled the motor thinking it was at least a running engine when the guy rolled it.
I cleaned the engine and had to break the timing cover off in pieces then drill and tap several bolt holes because the timing cover bolts were fused to the cover.
I also easily put a hole in a couple freeze plugs when I was cleaning the crud off.
I found several items of evidence in the van telling me the engine has about 115k miles on it.
I would prefer to save some money and was thinking about just replacing the freeze plugs and installing new head gaskets and run the engine as is but I am looking for advise.
