NeverSatisfied
Bigger is always better right? Here's my dilema-- I'm coming to the end of my year long 1976 frame off restoration/modification and I'm at the point of tire choice. My present modification list is a 5.5" suspension lift, with a Wristed Axle Housing, F250 shock mounts, rear inboard shock hoop, and Spring Rockers. I'd prefer not to install a body lift. I know the standard tire size to run with this setup is a 35" tire, but I'd like to put a set of 37" MTR's on my 8" wide bead locks w/ 3.5" back spacing.
I really want to run 37's, but I do not want this to limit my articluation in any way. I have the Warflares yet to be installed and have no problem putting them at the body line, but it looks like the front inner wheel tubs, and the rear inner wheel tubs are the limiting factors on upward tire travel.
The rear wheel tubs look like they can have some severe cutting done to them on the outter most side where they cover the rear tank filler hose and the would be front filler hose.
I was wondering if there was anyone else out there running this setup or had experience with it, and if they encountered any problems? Or should I just stop thinking so much, slap on a set of 35 MTR's, and be good to go?
Thanks in advance
Thanks in advance
