68 Broncoholic said:
Seems like a nice option, what did you use for the mounting hdw?
This might not pertain to you but a buddy added a big altinator. Can't remember which one but it cooked his battery over time. Started out making some hissing sounds and then smelt like rotten eggs.
Seems he was over charging the battery. He changed out the altinator with a stock type and got a Yellow top Optima. No more problems. Its nice to have a gell cell.
Generally speaking the 3G has a more stable regulator than the older style. The 3G's regulator's do require a sense line and if stock wiring harnesses are used for this they are prone to corrosion in the fusable link about 6 inches back into the harness. This then causes resistance which causes the regulator to think that the system voltage is lower than it actually is. Got to love fusable links.
I would also like to clarify that the Optima battery is NOT a gel cell battery. It is an AGM (asorbed glass mat) battery. As is the Orbital and Intimidator. This is an extremely common misconception that Optima has done very little to correct. (Which has always irked me). But at least about 5 years ago they started putting it in the really fine print on the brochures.
A gel cell is the only battery that can be mounted upside down or under water. It is a higher quality construction than an AGM, and also very expensive. They are not the best for starting applications either, but are absolutely the best for deep cycles in an extreme enviroment.
Here is a link to an old tech article:
http://www.svapowerproducts.com/html/batterey_articles.html
Now this may sound kind of funny, as I wrote the articles, but I do not agree 100% with what was stated in them. The information came from a very good source, but real life testing since they were written seems to lean towards GELS working alright (not awesome) in a starting applications, if they are oversized for the application they are awesome.
