4.0 explorer rad/shroud RAN INTO PROBLEMS
blazinchuck
hey guys, just picked up a 4.0 radiator. the 1st one i pulled looked like it was only 1" thick(4.0) so i went looking for another and found one twice as thick(another 4.0) go figure...not sure why they were different...hope i got the right one. anyway...hoping to hear what hoses yall used? ive heard 97v8 hoses will work, stock upper and a diesel lower...but if someone can simplify this for me...it would be much appreciated. im thinking bout starting this today...i'll keep checking back with my phone if someone can help.
i really dont wanna be chasing down hoses without some proof that they really work. ive running a explorer serp system so yall know what hose outlets are on my motor. thanks,Chuck
here's a couple comparison shots of the 4.0 vs. stock
blazinchuck
blazinchuck
ok...just gutted everything on the bronco and ran into 1st major problem. rad wont fit. i was getting worried once i saw the bottom mounts most EB guys were using...thos elook like they have plastic dowels straight down into round rubber donuts...mine has some plastic arms off the side...which is resting right on steering box!! i think i got my rad from a 95 explorer.
heres some pics
fungus
Kaneohe Bay, Oahu
Uhh, err, hey Chuck, what year explorer did you get that 4.0 rad from? She don't quite match up with the '91-'94 4.0L rad the rest of us boneheads are runnin' ie; seems awfully wide and the lower mounts are different. But hey, if she fits she fits!
As fer hoses: you want '99-'01 5.0L explorer upper AND lower hoses. Some time in '98 they deleted the external coolant/ oil filter thingamajigger and just ran a hose straight from water pump to lower rad outlet hence the '99-'01 hose reccomendation. Uppers are the same on all 5.0 sploders.
blazinchuck
blazinchuck
hey fungus...SHE DONT FIT...at all
'95 ploder...guess i got to go back to LKQ right now!!! see bout swapping it out for the right one! dayum, now the bronco is down....FML
fungus
Kaneohe Bay, Oahu
& you were right in your original post, they come with two diff rads; a single (thin) core and a two core. You definately want the two core (about 3" thick).
blazinchuck
blazinchuck
Thanks fungus...gonna head out and try to find one. Be my luck they wont have...just late models!
Sent from my DROID BIONIC using Tapatalk 2
fungus
Kaneohe Bay, Oahu
You should be fine. 3 years ago when I did mine you couldn't swing a dead cat in there without hitting one! Had my pick of the litter. See'um on craigslist all the time for parts even now. Good huntin' bro!
blazinchuck
blazinchuck
well, JML...lkq closed at 4pm. i called around and can get a brand new one for $95. means i still need lower mounts and a shroud from lkq. guess the bronco will sit here til tomorrow!
will i be alright running this 94 rad/shroud with the explorer serp and clutch fan??? i just want to make sure the rad can mount low enough and still use the stock 4.0 shroud without hitting clutch fan.
blazinchuck
blazinchuck
After looking at the rads on auto sites...I think I want the manual trans version
blazinchuck
blazinchuck
Correction ...looks like manuals were only single core like I found in the pull yard. Which means a new dual core is $140!
blazinchuck
blazinchuck
whats the best hose for the lower? i see in pics the lower water outlet faces down? is this a problem?
fungus
fungus
Kaneohe Bay, Oahu
Yeah, I think the auto trans was the one with the two core and integral trans cooler. The shroud should work fine with the 5.0 clutch fan. I posted some pics somewhere once upon a time ago with the 5.0 clutch fan sitting inside the 4.0 rad/ shroud, it's a perfect fit. You'll have to figure out the best way to mount the rad/ shroud to fit your fan while its attached to your water pump.
BOTH lower & upper hoses should be a '99-'01 5.0L explorer.
blazinchuck
blazinchuck
well...i gotta say...this has been a waste of a weekend!
went to lkq today, scored a 94 2 core auto radiator. got home and began...
1st off i have no body lift. and with the 4.0 shroud on the 4.0 rad ...the rad had to be mounted way to high the keep the clutch fan centered of the shroud. but now the rad was too high and the hood hit hard. so believe it or not with a little trimming on the stock EB shroud-it fit the 4.0 rad pretty nice. this shroud allow the rad to be lowered while keeping the clutch fan centered on the shroud...thats about as good as things got.%)
i didnt feeling like spending a hr or more at the auto store trying alot of hoses that might work on the lower...but i can tell ya, with no BL the later explorer 5.0 did not fit...in fact, the later 99-01 4.0 lower hose fit better(but was pretty tight getting onto the water pump. however the lower hose was squashed in 3 spots and rubbing the front cross member pretty hard.
im sure i could have use this rad if i went to a elec fan only...but i wanted to use a mechanical clutch fan.
as of right now...i'll be taking this rad/shroud back for a refund. im so aggravated i wasted all this time, fabbed up some brackets only to throw them away, and end the end...reinstall all the factory chit i took out sat
...all i can say, i really dont see this working out unless you run a 2" body lift or ya plan to run the Taurus fan...and even then not sure there is room. i already had modified my core support a while back(moved it forward bout 1.5")
ransil
I used something like an 85 blazer for a lower hose.
I looked up the diameter of the hose for the 94 rad and then check the diameter of the mustang water pump I use then went shopping from there.
My bronco does have a 3" body lift.
broncomatt
Spend the coin on a nice Howe or griffen and make your own shroud. Just my 2C.
