4 Door Bronco Project
NGABronco
Always Learning
N. GA now South Carolina
Hey broncman, I closed the ends on that cable bracket in your #6 & 7 pics.... on the second one I made!!! That was after the first one bent!!!%)%)%)
broncman66
broncman66
Spring, TX
You know, I was wondering if that bracket would bend or not... I figured most of the force would be on the inner cables, and the bracket would just be holding the steel sleeves. Better safe than sorry though, I'd rather overbuild now instead of redoing later :p Thanks for the heads-up NGA... what thickness steel did you use for your mount?
NGABronco
Always Learning
Can't remember, but I'll look in the morning. Try to get a pic, it's kinda muddy right now!!!;D;D I was surprised at the force put on it but if ya' look at a stock one it's pretty beefy.:cool::cool:
NGABronco
Always Learning
Hey Broncman, I believe mine is 16 ga., I used a piece of 1" angle and 4"x 4" flat for the down piece, boxed the ends and a center brace. Mine needed to hang lower for clearance, it's mounted to the bed and had to clear a piece of 2" sq. tubing in front of it???
Hope that helps.;D;D
SC74
That's as dirty as you got Stretch!!!???? :-[
broncman66
broncman66
Spring, TX
Thanks for the pics and explanation NGA! I built mine out of 1x1x1/8 inch angle iron... I might weld in a center support like you did but leave the ends open. Those cables look really nice too! Can't wait to get mine out for some trail rides... mine might come back a little muddier though ;D
broncman66
broncman66
Spring, TX
Well, after fighting the flu over Thanksgiving, then the sinus infection that followed that, I am finally feeling like I am back among the living. While I was sick I did get some parts ordered... new step drill bit set (can finally finish the e-brake stuff), and some beefy seat belt tabs I'll weld to the cage for the 4 point harnesses.
ImageUploadedByTapatalk1355105153.465328.jpg ImageUploadedByTapatalk1355105172.959936.jpg
This past week I continued the seemingly never ending body work on the front fenders... I am pretty sure whoever stripped these poor things must have used a weed eater with chains attached, with the time I have in these fenders, the filler, and all the sand paper I've gone through, it would've been cheaper to get new ones... oh well, hindsight is always 20/20. I've got most of the big stuff smoothed out on the passenger side, now I am dealing with pinholes and cracks in the fiberglass. The drivers side is still a mess, you can see in the unprimed pic how banged up they are.
ImageUploadedByTapatalk1355105512.930966.jpg ImageUploadedByTapatalk1355105528.431975.jpg ImageUploadedByTapatalk1355105613.886945.jpg ImageUploadedByTapatalk1355105672.653430.jpg
Today, was more body work, and I was able to get the e-brake handle cable run rough the floor and the cable equalizer finished, welded in and painted. Now I just need retaining clips for the cables and to figure out how I am going to connect them with a mid cable.
ImageUploadedByTapatalk1355106082.355615.jpg ImageUploadedByTapatalk1355106095.861419.jpg ImageUploadedByTapatalk1355106116.928756.jpg
broncman66
broncman66
Spring, TX
I got the rest of my parts in to finish the e brake stuff this week and thought I would check it off the list tonight, leaving all day tomorrow for body work...
As usual, any progress forward is accompanied with new found issues. I got the mid cable measured and cut (ended up using a piece of the old e brake cable), everything connected and adjusted snug.
ImageUploadedByTapatalk1355622806.533894.jpg ImageUploadedByTapatalk1355622820.188048.jpg ImageUploadedByTapatalk1355622841.463677.jpg ImageUploadedByTapatalk1355622857.712331.jpg ImageUploadedByTapatalk1355622873.532939.jpg
On to the new issue, hopefully there is an easy solution... when I pull the handle all the way up, the rear cables move about an inch and with the trans in neutral I can still roll the Bronco forward and back. When I release the handle the rear cables only return about 1/2 an inch. So after all this I still don't have a functioning e brake!
Should I adjust the tension on the cables tighter? I plan to try this in the morning... how tight should the cables be? My other question is, are there return springs in the drum to pull the cables back when the handle is released that might be out of adjustment or missing? The last time I worked on drum brakes was over 10 years ago and I haven't pulled these drums apart yet, was planning to check them when I put new tires on, I guess the cables might not even be connected in there. Any thoughts or experience appreciated, thanks!
broncoitis
You are probably gonna have to incorporate come type of linkage that will allow you to change the cable pull ratio. Basically, for every of cable that is pulled with the hand brake, the pulley will pull four inches of the drum brake cables. Hopefully that makes sense!
You just need to figure out how much cable needs to be pulled in order to engage the drum brakes. ;D
broncman66
broncman66
Spring, TX
Just got back from 4 Wheel Parts with 4 new 35x12.50r15 Pro Comp Xtreme M/T's! Early Christmas present from the wife. :-D Now I need to get them mounted on my other set of slots I have sitting in the shed...
ImageUploadedByTapatalk1356047683.881590.jpg ImageUploadedByTapatalk1356047704.511480.jpg
broncman66
broncman66
Spring, TX
Got some BC hood shocks for X-mas and got those installed, had to modify the lower brackets since I don't have inner fenders. They are awesome!!
ImageUploadedByTapatalk1358907671.144125.jpg ImageUploadedByTapatalk1358907743.435180.jpg ImageUploadedByTapatalk1358907760.474924.jpg ImageUploadedByTapatalk1358907785.358540.jpg ImageUploadedByTapatalk1358907805.208413.jpg
broncman66
broncman66
Spring, TX
Been continuing the body work and other pre paint tasks like pre fitting the flares, etc. Had MLK day off from work so I got the rear quarters sprayed. This was my first time painting with a compressor and spray gun, before I started, I told the wife I'd be happy with a 10 foot paint job, and I ended up getting a 5 footer :-D There is some orange peel, some dust specs, the remains of 1 bug, but I am pretty damn happy with it!!
ImageUploadedByTapatalk1358907927.026534.jpg ImageUploadedByTapatalk1358907952.100314.jpg ImageUploadedByTapatalk1358907990.389020.jpg
My garage paint booth...
The results...
ImageUploadedByTapatalk1358908142.793588.jpg ImageUploadedByTapatalk1358908224.761732.jpg ImageUploadedByTapatalk1358908269.531010.jpg ImageUploadedByTapatalk1358908300.159047.jpg ImageUploadedByTapatalk1358908343.426824.jpg
Working on getting the rest of the pieces ready for paint, hopefully by this weekend
Hank_
What an awesome project. Just read through the whole build. Great job on the paint and brake work. I will keep checking your progress.
Henry
DRBRONCO69
Chicago Mike
Chicago, Illinois
I have to ask, what is the wheelbase? Looks kool, be a fun tourism ride in downtown Chicago........Check out the sites in an EB. Can't wait to see it finished.
asinor
Tulsa, OK
Orange peel should be easy to clear up. I know how, but I'll leave the advice to the professional painters here :)
broncman66
broncman66
Spring, TX
Can't remember exactly, but off the top of my head I want to say around 128-129 inches... I remember it being shorter than my old F150 SCREW which I believe was 131". Definitely not a technical trail machine, but I can't wait to get it in the mud and sand ;D
broncman66
broncman66
Spring, TX
Henry
Thanks! I really appreciate it, I have learned so much from other members and all the info on here and am so glad to finally be applying what I've learned to my own Bronco
broncman66
broncman66
Spring, TX
Hey, I'll take any advice I can get, haha! I am a total noob when it comes to painting with anything other than a spray can, lol. I've read a ton of online paint and repair forums about surface prep, air pressure, wet sanding etc. but am still learning.
Trying to decide now if I can live with the orange peel and debri for a year or two until I have the funds to get the WCB prerunner fenders and bedsides, or wet sand and polish what I have... I just want to get it back together and on the road so bad ;D
