4 Door Bronco Project
broncman66
broncman66
Spring, TX
Got the tires mounted last night on the second set of slots that came with the Bronco then got them on the Bronco today. Measured before and after off the center bar on the cage and the new tires rose the height 3 inches ;-D
ImageUploadedByTapatalk1360452015.577868.jpg ImageUploadedByTapatalk1360452040.546950.jpg ImageUploadedByTapatalk1360452055.149304.jpg ImageUploadedByTapatalk1360452077.802229.jpg ImageUploadedByTapatalk1360452102.323957.jpg
While I had the rear tires off I pulled the drums to take a look at the rear brakes... passenger side definitely needs some help. Leaking cylinder and broken spring, that I don't know where it came from, need to study up on drum brakes I guess...
ImageUploadedByTapatalk1360452483.802618.jpg ImageUploadedByTapatalk1360452499.659346.jpg ImageUploadedByTapatalk1360452524.673734.jpg
jcpetrson
Your progress is moving fast. The color combo is great. I want to see some mud on that bright white. :p
broncow72
Village Idiot
Spring,TX.
Loving the progress. Those rear brakes are all newer hardware, hmm. Cylinder leak is probably due to sitting for so long. And yes, that motor is a smooth runner. Those 35's and the 4.11's should make it friendlier on the freeway. I remember pulling 3500+ rpm just to keep up with freeway speeds.
broncman66
broncman66
Spring, TX
4 Door Bronco Project *Paint Update*
Thanks guys! Progress has been slow the past couple weeks, unfortunately I've been busy with a bunch of other stuff, but hope to get back at it later this week. Goal is to have it together enough to get it inspected and registered by the end of my spring break (mid March), it'll be tough, but that's what I'm gonna shoot for, haha.
I sprayed some bed liner on the fender flares to matte them out a bit, but then the shiny fasteners that come with the Warflares didn't match the color scheme, so I ordered some black hex head fasteners with nylock nuts, kind of a pain to tighten them all, but I love the look. Also ordered a new rear brake spring kit for both drums and a passenger rear wheel cylinder. Alan, if you want to see her in person, I might need some help with that cylinder and bleeding the system... and I'll provide beer ;-D
ImageUploadedByTapatalk1361841221.956503.jpg ImageUploadedByTapatalk1361841242.447599.jpg ImageUploadedByTapatalk1361841272.896677.jpg
broncman66
broncman66
Spring, TX
Finished up the body work on the drivers front fender and sanded the sags out of the front insert this week and got them shot with paint this evening. These were the last 2 pieces I had to paint, so now the next big project to tackle is pulling the cage, seam sealing the inside, and lining the bed...
ImageUploadedByTapatalk1362795063.643517.jpg ImageUploadedByTapatalk1362795089.588269.jpg ImageUploadedByTapatalk1362795105.591198.jpg ImageUploadedByTapatalk1362795122.305572.jpg ImageUploadedByTapatalk1362795147.154986.jpg ImageUploadedByTapatalk1362795200.846563.jpg
broncman66
broncman66
Spring, TX
Put the fender and insert on today, the grill is next, the reassembly stage sure is fun, finally seeing in person what I've been picturing in my head ;-D
ImageUploadedByTapatalk1362865956.296936.jpg ImageUploadedByTapatalk1362865975.912379.jpg ImageUploadedByTapatalk1362866000.204630.jpg
broncman66
broncman66
Spring, TX
looking good
Thanks! Got the grill reassembled this morning and bolted on the front, then had to get cleaned up to go be in a wedding... tomorrow hope to hook up the lights and make a few little clearance adjustments between the hood and grill and start figuring out a way to get the cage out.
ImageUploadedByTapatalk1362973238.051090.jpg ImageUploadedByTapatalk1362973273.950883.jpg
broncman66
broncman66
Spring, TX
Wow, been snooping around and truck is lookin good! It's coming together.
Thanks broncoitis! Got the headlights, blinkers and running lights all hooked up the other day. Today I started cleaning up all my painting stuff and attempting to clean some work space in the garage. Then gutted the interior and got the cage all unbolted and pulled out. It took me, my father in law and a neighbor to get it out and we were struggling! Tomorrow I plan to prep and seal the interior and possibly lay down the bedliner, depending on how long everything else takes, also need to weld my seat belt tabs to the cage and paint it... wish I was on spring break every week ;-D
ImageUploadedByTapatalk1363139601.772484.jpg ImageUploadedByTapatalk1363139615.576301.jpg ImageUploadedByTapatalk1363139651.098261.jpg ImageUploadedByTapatalk1363139675.822500.jpg ImageUploadedByTapatalk1363139700.953029.jpg
74fiberglass
Can you post some close up piks of how the rear door hinge pillar and front door
Striker meet . I never seen how they match up
Thankx
broncman66
broncman66
Spring, TX
Spent over 12 hours in the garage today and got the tub fully prepped for the bedliner tomorrow. Filled holes, ground down some welds, sanded the whole thing down and coated the inside with Chassis Saver. Never realize how many unnecessary holes are in a tub until you start filling them :p
ImageUploadedByTapatalk1363234464.052283.jpg ImageUploadedByTapatalk1363234482.359322.jpg ImageUploadedByTapatalk1363234509.245565.jpg ImageUploadedByTapatalk1363234531.743324.jpg ImageUploadedByTapatalk1363234548.951787.jpg ImageUploadedByTapatalk1363234563.060305.jpg
broncman66
broncman66
Spring, TX
Rolled on the Monstaliner today. Since it's stretched, I bought their 2 gallon kit and had more than enough. They recommend 2 coats but I had enough to put 2 heavy coats in the whole tub and 3 on the bed floor and floorboards, 2 on the bulkhead, and 2 coats on the rockers. First impressions are it is nice stuff, hope it is as durable as the reviews say.
ImageUploadedByTapatalk1363317083.221656.jpg ImageUploadedByTapatalk1363317103.020618.jpg ImageUploadedByTapatalk1363317129.104361.jpg ImageUploadedByTapatalk1363317149.860740.jpg ImageUploadedByTapatalk1363317190.376848.jpg ImageUploadedByTapatalk1363317207.655903.jpg ImageUploadedByTapatalk1363317221.006865.jpg ImageUploadedByTapatalk1363317241.051334.jpg ImageUploadedByTapatalk1363317264.288591.jpg ImageUploadedByTapatalk1363317312.578783.jpg
