mdshore
i measured the front from the bottom of the frame to the top of the dana 30 , 11 inches on the dot. the back is currently a saggy 10, im just starting to see spline on the driveshaft .. what size springs should i get , and should i shim it for better angle.. ? lengthen the driveshaft im assuming ill have to.
it is a duff coil front. im not sure how much the leafs will settle in on 3.5 or 4.5 leaf kit, especially since ill be running mostly soft top , no top.
