4 Link Rear Setup Help
Dbteak
I would like some feedback on my 4 link set up. I have never set one up before so I have no real world experience with the numbers the spreadsheet spits out. From what I read the set up should work except for the uppers are not at a minimum of 45 degrees. Not sure that could be achieved without having 24" links. The axle cycles with no binding and has about 3/8 rear steer and the pinon angle increases as it droops. I took some screenshots of the calculator to look at. Not sure what other information would be needed to help with the set up. Doug
Yeller
Rogers County Oklahoma
That would be a very neutral set up, it will work just fine and be stable. I would lower the frame mount on the uppers a little, I prefer a bit more AS, but would have no issues with what you have. Please post a pic of the graph, converting all of those numbers to an image makes my head hurt. The image would help a lot with any final critiques, but I doubt there are any.
Dbteak
Dbteak
Here is the plot. Hope it helps.
Dbteak
Dbteak
Here are the numbers lowering the upper frame links 1 inch. Thanks in advance for all the help and any advise.
Yeller
With the constraints of a bronco that's about as good as you can get. I like the slight boost in anti squat of the second one. It's not enough to make a noticeable negative effects but will make a huge difference when your tires are hunting traction.
