Tias
I picked up a partially dismantled 69 Sporta while back and am just in the process of dealing with the floor pans. I thought it had a 3-speed transmission with a floor shift conversion, but after pulling the transmission, scraping the layers of gunk off, and a bit of education thanks to google, I end up having a 4 speed toploader. So the 5 speed conversion is on the back burner and I am sticking with what I have transmission wise for now.
The PO looks to have had no hesitations in butchering the floor pans, including removing the driver side front channel portion which angles.
For those of you who have done this conversion, how much of the channel did you actually need to cut out (photos would be great)? I am contemplating putting on a 1" body lift and then figuring out what a decent repair solution would be in order to add some floor support here again, but maybe I am worrying about nothing if everyone with the 3 on the floor conversion are also cruising around with a bunch of the fwd channel removed.
