4 Wheel Disc Brake Master Cylinder Question
chrisw1214
First off I'd like to say you guys have an awesome forum! I've been a long time reader and your search function has answered many a question for me. Thank you for that!
But (fatal last word I know lol) I am at a very frustrating point with the 4 wheel manual disc brakes I just installed. I have the TSM kit in the back with chevy calipers and I've installed the 78-79 big bronco knuckles etc up front with thunderbird calipers.
Now my question is simple ( again my second fatal last word) which of the numerous master cylinders should I install now?
The big reason for this question is I could not get a firm pedal whatsoever no matter how many times I bled the brake system with the stock 74 drum brake master cylinder.
Thanks in advance,
Chris
thegreatjustino
Red Head Grease Monkey
Stockton, CA
A lot of guys are using a Corvette M/C with four wheel discs. I'm using a four wheel disc M/C off a '78 Lincoln Mark V. Works well for me. I'm not running a booster.
RustyShackelfor
Centerville, TN
I believe they usually use the corvette MC when they are using an astro HB, though.
If you are running no booster, just pick a 4 wheel disc brake Ford MC. If you put on a booster, run the make that matches it.
C
chrisw1214
Thegreatjustino - I picked up the Lincoln master cylinder. Should I pick up a Lincoln push rod as well or will my stock bronco one work for it?
thegreatjustino
Stockton, CA
Before you change anything over, measure the distance from the firewall to your brake pedal on your current configuration. When you install the Lincoln M/C, you'll want to have the same distance from the firewall to your brake pedal. After thoroughly bench bleeding my Lincoln M/C, I was able to re-use my stock push rod.
