4 wheel drive question
G
Guest
Guest
I have a 66 ford bronco with a 302 and mild cam with hearers and full exhaust. It also has a 3.5 inch lift with 35 inch bfg tires. My question is since my four wheel drive is not hooked up do you think that I can still take it four wheel driving if I just air the tires down. Without getting stuck. Mabyee some light sand and rock driving .
Thanks Wesley
GRIZZLY
Lakewood, CA
Locker in the back would help. If you have an open diff you'd have very high odds of getting stuck in either rocks or sand. Still a possibility with locker too but less of a chance. A lot depends on common sense and knowing when NOT to use the right hand pedal...
Desert Thrasher
Are you locked in the rear? If you are locked you can go on some decent trails, but nothing extreme. Make sure you have a buddy with a winch or tow strap because you will get stuck. Sand running should be fine as long as you keep your wheel speed up and dont dig in.
2 wheel drive pre-runners do sand all the time, although they are a lot lighter than an EB. I would stay away from rocks, you definately need 4wheel drive for that. Good luck and have fun.
GRIZZLY
Lakewood, CA
Also for sand, stop facing downhill. Less chance of digging in. I spent a whole weekend at Glamis with my last bronco after wasting the front end and did fine. Just watch what your doing....
supermottl
Indian Harbour Bch,
Beachin and sand is ALL I do with my EB. I would be very cautious while running on light fluffy sand with only 2 wheel drive. The front of EB are usually heavier than the rears and w/o 4 wheel, those back tires are just gonna rip loose in a second. A locker will help, but soft sand NEEDS 4WD. My GFs CJ5 has a locker, and I still managed to get it stuck in 2wd.
If you try it, make sure you have tow ropes or winch, shovel, and air down to like 8-12 psi. make those tires balloon out..
And get that 4wd working!!! ;D ;D
good luck
77TexasBronc
Baytown Texas
My god man! ...A 2 wheel drive bronco? there is something wrong with this picture...Seriously, if you take it easy and use your head you can still play in the light stuff, fire lane roads and such "not sand" ..invite some buddies to join you incase you run into trouble. Better yet invite them over to help get the 4 wheel drive working then really go wheeling ;) ;D
G
Guest
Guest
Thanks guys I will give it a shot and just use my wench when needed.
