    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
MO 435? 4 sale
Status
Not open for further replies.
roystoys
4 speed trans remove from 1985 f250 was behind a 460 2wd my unstanding it 435 and the 2wd is the one for the conversion , truck ran fine was rolled engine is going n my 79
Cheeop
St. Louis
Can anyone confirm that this year has the 28 spline output shaft and square bolt pattern needed for the eb conversion? I'm very interested if this works with adapters.
75junebug
NW Houston Tx
Could be a T18 or T19. Does it have a cast alum top or steel top? NP435 will have the alum top. Gear pattern is also different . NP 435 is: Low top left reverse bottom right. T18/19 is opposite that if I remember.
R
roystoys
It has cast top and on top cover has t19-148 on left side #13-09-065-911 borg warner 4 bolt rear tail but its not square I thought I read somewhere it was the right one if any one knows please inform me just trying to recoupe some expense and pass on some parts but dont want to sell soming that wont work for the purpose either thanks reverse is over and down on right
thegreatjustino
Red Head Grease Monkey
Stockton, CA
If it says Borg Warner on it, it's not an NP435 for sure. NP stands for New Process which was the manufacturer of the NP435. What you have may still work in an EB though. Just need to do a little more research to verify.
75junebug
NW Houston Tx
Yes it can still work. My brother had to slightly modifye the NP435(steel one from one of the vendors) by welding and re-drilling the bottom holes. I don't know if it was just this particular tranny I gave my brother, but it had a huge pattern...ie , you "row, row, row your gears, all across the cab" in the tune of row, row , row your boat......
R
roystoys
Borg warner on the side makes it not a new process I must have been having a blonde moment
thegreatjustino
Stockton, CA
The aluminum Advance Adapters that most of the vendors sell now are made with two bolt patterns so they'll bolt up to square or trapezoid patterned transmissions. The same adapter will now work with an NP435 or T18
bax
Old Member
However all the t18/19 are 32 spline outputs. Plus the trans is 1'' longer than the 435. This trans works well with the 205 transfer case.
broncnaz
Output spline count really needs to be verified on the later 2wd transmissions as some of the later 435's came with the 31 spline outputs so Id verify before buying or else you may need to spend another $100 to make it work. You can usually get correct 2wd NP435's for less than $150 so having to spend a extra $100 plus work involved in swapping the output shaft is not really worth the cost.
Status
