4link build
bronco69drp
Cordova TN(memphis)
my spring 4link project:
1)move the rear axle back 14''
2)four link the rear axle & use coil springs
lower links: 1.5x.500 wall dom sleved with 1.75x.120 wall dom
upper links: 1.25x.620 wall dom
all hiem joints 3/4-16 cro-mo hiems
tonto
That pic of the back of your bronco looks like you narrowed the tub or did you boat tail it?
Gummi Bear
If you moved the axle back 14", how do you keep the rear tire out of the tail light post at full stuff? Even with a dovetail it seems like it would hit.
Tell me what you did. I'm thinking that I'll get 5-6" out of mine before it interferes. My thing is though, I'm not going to dovetail the back, I always want to be able to run a full top and doors.
Projp
Tell me what you did. I'm thinking that I'll get 5-6" out of mine before it interferes. My thing is though, I'm not going to dovetail the back, I always want to be able to run a full top and doors.[/QUOTE]
I moved mine back 7.5" and it clears with 37" tires.
Gummi Bear
Thanks Prop.
Would you mind sending me some pictures so I can see what you did. I want 100-103" WB when it's all said and done.
Projp
The computer with my pics in it just died. If I can't revive it I will take some new ones.
Jeff
Projp
I am sitting right now at 99.5 with only moving the back. I started by moving the leaves as far back on the frame as I could, which is about 7.5". After twisting my 9" housing I found a Tera 60 and linked it. I might get an inch or two more back, but it is not going to come easy.
UNCLEBEN
Boise, Id
Projp
When you moved the leafs back did you just cut of the brackets and move them back?
Do you have any pics of it on leafs ?
I am thinking about doing this at the same time as a shackle flip.
Projp
7.5" is about the limit without extending the frame. The rear of the frame should be boxed. I just ground off the old brackets and reused them.
I cut the 23 gallon tank to fit between the crossmenber and rear of the bed and raised it so it was flush with the crossmember. I havent had any problems hitting the crossmenber or tank.
I am no body man, but I did the best I could.
bronco69drp
bronco69drp
Cordova TN(memphis)
i extended the wheel well back all the way & trimmed the body as close to the tail lite posts as i could. but what really keeps my tires out of the body is i limit the up travel to only about 6''. i reset my shocks to 35% up travel & 65% down travel. i did this to allow for more axle articulation while crawling over rocks. i dont jump my bronco so the up travel is no sacrifice.
i also use extended bump stops.:cool:
my wheelbase is now 106''.;D
bronco69drp
bronco69drp
Cordova TN(memphis)
got the fox2.0 coilovers installed:D
Gummi Bear
I like where you're going with this.
Got some more detailed pics showing the upper mounting for your coilovers?
MikeEB
Grand Junction, CO
Looking REALLY good. When you get around to pics how bout some clean side shots showing the entire WB and some pics of how your front is set up.
Keep up the good work.
Mike
